Brief Description: Mixture arm reset/reflective material install
I moved the mixture lever one click due to cowling interference. After readjustment, Kris worked the mixture control and I watched the action. Now I have 1/4" clearance and great action. I removed the lower cowling and applied the Vans engine compartment heat foil. I had originally ordered 6', but ran short, so I ordered 3' more. I also ordered their cowling plugs. When all the foil is applied, I will seal all the joints by brushing on epoxy.
