TERRY'S WEB SITE
Date:  11-9-2015
Number of Hours:  4.40
Brief Description:  GP access door opening
Started to work on my shore power connection. I drilled out 6 AN426 fuselage rivets and made a doubler template out of .025. When all my fit up is done, I will make the real doubler out of .032. The template is to help keep things aligned. It will be far easier to make a door and use it to cut a hole in the fuselage rather try to fit a door to an existing opening....with a doubler in the way. Also, when done, the doubler will be riveted on all around its perimeter and be alodined and primed.
GP doubler
GP doubler
GP hinge fit
GP hinge fit
