Cut the ground power access door in the fuselage and made a doubler out of .032 aluminum. I also made the access door out of .025 AL and reinforced it with .032. At the hinge end I added an additional 1/8" shim and at the latch end, I made a striker out of .063 x 3/4" angle. I miss drilled the door, so tomorrow I will make another one.
