TERRY'S WEB SITE
Date:  11-14-2015
Number of Hours:  3.00
Brief Description:  Ground Power
Cleaned all of the rivet holes removing the paint and installed the door doubler, door striker, and aft section of the hinge. Next I assembled the door, door latch, doubler and hinge. The door was installed along with the door spring and hinge pin. Once tested for clearance, the hinge was safety wired. Next, I installed two 1/4" nut-plates that secure the solenoid, and the rest of the brackets. After all was riveted, I added the 5 amp breaker and 12V LED.
Ground Power Access Door
GP Unit
GP Unit
GP Unit
GP Unit
