Rough sanded the right lower door. As hoped, the epoxy/micro leveled the few light waves very well, leaving a nice flat door surface. Next epoxy/micro was added to the upper left door which sits about 1/16" lower then the cabin top. Also, Epoxy/micro was added to the cabin around the right upper right door because the door sits about 1/16" above the cabin. Epoxy/micro in these two areas will level the entire top surface.
