Removed the doors, hinges and pin guides. The door channels were sanded and an epoxy/micro mix was added to smooth out the various areas. I finish countersinking the door cylinder bracket holes getting then ready for the final install after prime painting. I used a fiberglass spreader to put a skim layer of epoxy/micro to see if What it is going to take to fill pin holes and the fuselage grain.
