I sanded and fit all the forward and aft panels. After removing the center door blocks, I filled in that void as well joining it to the rest. Next the center console was cut off about 1" past the front vertical side. Jim will pick this console up and finish it for me. Using the heat gun at about 325°, I reset the memory of the front panel where they surround the air vents so they do not interfere. Once heated and shaped, I held them in place till they cooled off.
