TERRY'S WEB SITE
Date:  8-14-2015
Number of Hours:  7.00
Manual Reference:  45.18
Brief Description:  Window joint work
Sanded the small voids I filled yesterday on the windscreen fairing. I am done with the fairing for now. Next I finish sanding about a 1" strip (1/2" on cabin cover, 3/8" on windscreen and about 3/16" of Lord Adhesive for the joint. After sanding, I blew off the dust and wiped the joint down with alcohol. After it evaporated, I mixed up a small batch of GFlex/Cabasol epoxy to fill in any low areas in the joint. When it cures, I will sand flush and will have established a flat surface to lay my two layers of fiberglass. I cut strips of BID glass in 3/4" and 1" strips to be used on the windows. I also sanded the aft window/cabin cover joint, cleaned with alcohol and applied GFlex epoxy/cabolsil mixture to the low areas.
Window joint
Window joint
