TERRY'S WEB SITE
Date:  8-19-2015
Number of Hours:  7.20
Brief Description:  Window joint work
Yep, more of the same. I laid two layers of glass on the left aft window, rough sanded the co-pilot door window and prepped the pilot door. I took a photo of how the Lord Adhesive spread under the window. This won't be seen once the BID fiberglass lip is laid and the windows are final painted. If you look close, you can see the AN6 washers used to adjust the depth.
Window joint work
Window joint work
Lord sealant covered well
Window joint work
Window joint work
