The cabin/fuselage joint was filled level with epoxy/micro mixture so the BID fiberglass would sit flat and not have any cavities underneath. I plan to tint my top coat gray so I added black coloring to the base. The color will help guide me when sanding. Once tacky, epoxy was applied and the 1" strip if glass was attached. After stippling, Clean peel was applied. Tomorrow the joint will be sanded and the area will be blended in.
