After removing the clean peel, I sanded (#80) the BID glass that covered the cabin/fuselage joint removing all the high spots. The joint was then blown off with filtered air and vacuumed. The area I wanted to add fairing to was marked out with tape and then wet out. The epoxy/micro mixture was added and leveled. After a few minutes, I removed the tape that outlined the area being worked. This area will get sanded tomorrow.
