Shape sanded (#80) the cabin/fuselage joint. It cleaned up very well. I plan to finish sand it when the rest of the fuselage is ready to finish sand. I temporally installed the door seal all around the door so that when I shape the door it is setting correctly. I covered up the right door way with plastic to keep most of the dust outside the fuselage and started to adjust the fit of the door by sanding the edge. Spent the afternoon shaping the door, but did not finish. Getting closer.
