Removed the door and sanded the upper co-pilot door/fuselage joint and applied epoxy/micro mixture to the threshold part of the door and closed it till tomorrow when it will be cured. I sanded the pilot aft door/fuselage joint and prepped the forward section of the door jamb. I applied the epoxy/micro mixture to the forward door/fuselage joint and closed the door. The joint was then topped off level with the fuselage side. Doors are looking lots better.
