TERRY'S WEB SITE
Date:  9-7-2015
Number of Hours:  7.50
Brief Description:  Cabin Fairing
Sanded the left door jamb (forward/aft) where the pin guides will sit. I temporally installed them. I sit the rear one on AN washers because it is not thick enough. I have two on order. They will need further adjustment before it is all done. The door mechanism is working great. Next I installed the third (center) Plane Around latch. They too worked well. They will be removed one more time when I paint the doors. After making sure I had .015" around the right door, I added vinyl tape to the aft right door and smeared it with mold release. I then put a small layer of epoxy on the outside. This will be sanded when cured, and the door area to the right will be done. They will then be leveled together.
Door Cam
Door Cam
Guide pin bracket
Guide pin bracket
Aft fariing
Aft fariing
