Now that the cabin cover cover will not be removed again, I wired the overhead console and cargo bay lights. This connection is aft of the cargo bay bulkhead at the top. After soldering the wires, I tucked them inside the console through a nylon bushing. I left about 8 inches of wire so that if needed they could be pulled back out. I also received my air controller back from Aerosport products. The first one did not function. Zac said they found a faulty solder joint on the board which was causing problems on many planes. They send me a new board to install. I also installed the servo motor valve system and connected the SCAT tubes. This will have to be removed one more time when I rivet the upper fuselage skin on, aft of the cargo bay.
