I spent quite some time reading the lock handle install instructions.... and glad I did. Zac is doing a little research for me, because a couple of their numbers did not make sense to me. OK, Zac called, the photo was updated with the new numbers, and the text still needs updating. I got an at-a-boy! It took a couple hours to do a final check/route of the wires looms on the right side of the fuselage. Once looking orderly, I started to fit the Aerosport interior side panel. Wow...was it time consuming. But in the end, looked pretty nice. I still need to place the screws. Not sure what type of screw or screw/cap combination I plan to use. More on that later.
