TERRY'S WEB SITE
Date:  7-1-2015
Number of Hours:  7.50
Manual Reference:  45.13
Brief Description:  Aft cargo bay work
I installed the left door and adjusted it to a good fit. I then installed the third member latch from Plane Around. I also installed the door gas cylinder brackets on each side. I applied a 1/4" bead of clear RTV between the cargo bay aft bulkhead and the overhead console. This will prevent any outside air from leaking in this area.
Plane Around center latch
RTV aft overhead console
Door install and fit up
