Larry came over this morning to run the rivet gun and I climbed inside to buck the upper fuselage section aft of the cabin cover. I put a 1/16" bead of pro-seal aft of the cabin cover CS4-4 rivets to stop rain water from entering at that location. It took about 2 1/2 hours all together including the blind rivets. I also used the pro-seal and blind rivets to install the 2" overhead air ducts. The Aerosport air valve will connect to these. I also reinstalled and torqued the four longeron bolts on each side of the fuselage. They were removed to give me access to the back side of the rivets. I also started to make spring clamps that will hold my rear windows in place while the Lord Adhesive cures.
