TERRY'S WEB SITE
Date:  7-16-2015
Number of Hours:  8.00
Manual Reference:  43.8
Brief Description:  Windscreen prep
I cut, trimmed and sanded the Cee Bailey windscreen to fit. I then sanded the cabin surface where the windscreen will attach and added #6 AN washers to being the windscreen up to level with the cabin cover. I tested the Sure Strip paint remover from ACS on the glair screen edge to see how it will work. After 4 minutes, the black two part epoxy top coat had bubbled up and was ready to remove. Once removed, I reapplied the remover on the base paint. After five minutes, it too bubbled up and was wiped off. Tomorrow, I will double check the windscreen fit and then remove the paint where the fiberglass E-Glass windscreen will be laid up.
Winscreen sand
Winscreen sand
AN6 washers installed
test paint remover... worked great
