I finished some minor adjustments in the windscreen and then prepped and alodined the fuselage surface. I took one more fully installed look at it and marked where it laid the best. Kris and I rehearsed installing the windscreen until we found the perfect combination of moves that would allow us to set the screen once and not have to move around. Once we agreed on the sequence, we placed a 1/2" bead of LORD ADHESIVE on the cabin cover lip and installed the windscreen. It took the two of us about 45 minutes to glue, clamp, check all the joints, remove the exterior tape....remove the excess in the inside, and then remove the two runs of tape on the inside. Once done, we riveted the five securing camps onto the fuselage and set weights on the windscreen. All went well. Glad this one is done.
