TERRY'S WEB SITE
Date:  4-13-2015
Number of Hours:  8.00
Brief Description:  Blast tube install
I installed three blast tubes. One is plugged into the fuel pump cooling shroud. The other two are pointed to the L/R magneto. I made a T bracket that connects to a cushion clamp to hold the magneto tubes in place. Next, I wired the seven terminals on the B&C backup regulator. I really like its final location, which is out of the way, yet easy to remove if needed. Three of the wires from the regulator are connected to P1, so I routed those to the front co-pilot side. The rest of the day I spent on the center counsel. This unit will house all the headset connections but will be removable during the annual inspection.
Blast tube bracket
Blast tube bracket
Center console fit up
