I installed a TNC at the Garmin 650 GPS and ran it down the left side to aft of the cargo bay bulkhead. I also installed a TNC for the MultI Function Display (MFD) SXM and a BNC for the MFD GPS and ran them down the right side to aft of the cargo bay bulkhead. I installed the ELT mounting bracket and mounted the ELT. I ran and connected the ELT controller wire and signal wire. I may have to make an antenna wire for it because the one that comes with it is pretty short. I de-pinned the Mini-X magnetometer and ran it and two shielded wires down the right side to aft of the cargo bay bulkhead where the Garmin and Mini-X magnetometers will be located.
