Brief Description: Wing root holes and connector fit up
I fly cut two holes and fit-up my wing root electrical connections. I am using a series one, 37 pin connector and back-shell on each side. The design of this device makes it easy to vary wire size by changing pins. I squared them with a level and drilled the four holes in the flange. I also temporally installed the audio cables. I changed the routing so they were two feet too long. Jason, at Aerotronics, offered to shorten them to fit, so I installed/marked/removed and mailed them back to him. Should take a couple weeks. I then installed the pilot and co-pilot audio jacks in the center counsel. I have to install both passenger head sets, and will tackle that tomorrow.
