Brief Description: Drill center console, COM 1 BNC
Made a template to locate the rear seat passenger audio jacks in the Aerosport center console. After pre-drilling 1/4" holes, I used a step drill to increase each hole to accept the insulation washer. Test fit each jack and disassembled. The console is ready to wet sand and clear coat. Next, I installed the RG400 coax from the Garmin 650 (COM1) to the bent whip antenna location under the left rear seat. Adding a PEX 3/8" water line to use as a wire conduit made running this wire easy. The wire went right to the hole. During construction, I also added an access plate to facilitate installing the BNC connection. After that, I ran the Garmin Transponder RG400 coax from the panel to the TED antenna location under the pilot seat. BNC terminals were added on each end of the transponder coax.
