I primed the Mini-X mounting shelf, the Garmin GMU22 bracket and the Garmin Pitch Servo Motor bracket. While it was curing I installed RG400 coax from my COM-2 radio to the COM-2 bent whip antenna located under the co-pilots seat. I also installed BNCs on each end and connected the one located at the panel to the COM-2 radio stack. I also ran RG400 coax from the ADS-b panel mounted instrument to its TED antenna located aft of the cargo bay bulkhead, just left of the pitch autopilot servo motor. I installed a BNC connector on the panel end and attached it to my ADS-b unit. Both primed brackets were installed. I also finished the static line connections in the tail section. On the line going forward, I added a 1/4" SS bushing to the Safe-Air static "T" to clear the bulkhead inner edge.
