Brief Description: Rear overhead air controller motor wiring
I wired the 4-pin Molex connector at the panel for the Gretz heated pitot controller. It runs to the wing root where it will be placed into a 37 pin connector. I added a bushing to protect the 650 GPS. Antenna wire and the main relay activation wire. I installed the overhead air controller. I used a left over "J" skin stiffener and riveted to the center skin stiffener with a couple new AN426. This will hold it in place until the skin is riveted. The controller will be attached with two nylon ties so that the controller is easily removable, yet sturdy. I also soldered the controller lead wires to the shielded 3-connector wire I ran for it. I wired P-12 at the Garmin GMU22 connection and also at the panel. Once the panel was done, I routed the wires up under the panel.
