Brief Description: Battery mounting / pitch trim wiring
I wired the elevator trim servo this morning. I found out that I did not order the back-shell for the CPC I was using, so I did not place the pins in the CPC. When the back-shell arrives, I will install it and set the pins. I also started to work on mounting my Odyssey PC925L Absorbent Glass Mat (AGM) battery. Because it is an AGM, it can be mounted in almost any direction...except upside down. The "L" means the B- terminal is on the left side which is what I needed. I added a piece of aluminum angle onto the battery tray and secured it with nut plates. I brought the panel ground and battery ground together which will give the panel an excellent ground. I cut all the cables to fit and have just a little #2 left over. Tomorrow I plan to alodine the parts and clean the various surfaces to get an even better ground.
