Brief Description: Seat modification. Control Stick D-Sub
After installing the pilot seat a couple times, I realized that I needed to add nut plates to the slide locking mechanism in order to facilitate an easier install. Next, I used a meter to validate the control stick wiring matched the schematic. Then cut the cable where the D-Sub was to be installed. I installed the D-Sub pins on the stick end and sockets on the harness end. Once complete, I used the meter again to validate my D-Sub was connected correctly. Tomorrow I will do the pilot side.
