I removed the AOA data switch I installed two days ago and added a 3/8" piece of nylon to it. Once fastened to the .063 aluminum, I used a drum sander mounted on my drill press to machine it to the exact same level/shape as the aluminum. This will give the switch flag a wider, non-metal surface to slide on. I made some brackets and fastened them to the rear spar to support the wires that will be placed there. All will be covered by the flap guard. I also wired the flap position sensor and AOA data switch and ran both wires up to the panel. They will be added to the bundle that plugs into P1 and P5 CPC connectors. I decided to secure any/all wire service loops with T&B tie-wrap nylon mounting plates.
