Brief Description: Cargo bay switch, boost pump wiring
Removed a few wire bushings I installed the other day because they were not large enough. Fortunately, I had the next size larger on hand. I pulled a few more wires and wired the cargo bay light switch. I found a gray 2" snap cover that fit perfectly and drilled a hole in the center to mount a switch. I soldered on some lead wires and added a Molex connector. Access to the switch is great once the cargo door is open. I also ran the wires for the L/R door status indicators. They will be wired in series so that if either pin is not located properly, it will be indicated. I ended the day wiring the boost pump and boost pump annunciator. The boost pump wire is a red #14 and the annunciator wire is a red #22. The annunciator gets its power (B+) from the #14 wire and is protected by a 2 amp in line fuse located in the service loop of the boost pump.
