I replaced the AN3-5 rear seatbelt bolts with AN3-5 stainless bolts, washers and nuts as recommended by the RV10 builders group due to their close proximity to the GMU22 Magnetometer. I installed the blue flood light strip on the underside of the glare screen between the hand holds. The strip was twice as long as needed and you cut to length. I tested it and it will look great. I took the part I cut off and reattached two new leads and installed shrink tape just like the manufacturer did, so rather then pitch the part cut off, I have a replacement. My OAT sensor will be located on the second inspection bay cover on the right wing. After I decided on the location, I had to order 15' of #20-3 conductor wire. Next, I started on the four antennas located on the top side aft the cargo bay bulkhead. One GPS, one GPS/XM combo and one ELT. Because the GPS/XM share the same mount, I need only make three doublers.
