Brief Description: P5 CPC wired, AUX 12V installed
CPC P5 consists of three trim servo motor wire looms (5 wires each) for aileron, elevator and rudder. It also has three wires from the flap position sensor. Since I have all these wires pulled, I spent time today trimming and pinning these wires. Once the pins were installed, I added them to the mating CPC P5. The two halves were joined and tucked away under the panel. I also installed the 12V AUX power connection. I put is on the co-pilot side just under the seat where access is easy and there will be no carpet installed.
