Brief Description: Pitot and AOA bulkhead fitting install
This afternoon I installed the pitot bulkhead fitting acquired from Grainger and ran the pitot line from the wing root to the connection on the sub panel. Next I installed the two AOA bulkhead fittings I acquired from McMaster Carr. From there I installed the lines (blue &green) at the wing root and ran them up to the AOA controller. I also attached the pitot (red) and static (clear) lines from the pitot/static system to the AOA controller.
