Connected all the pins in P1 today and routed them both under the panel and hooked them together. After testing the system, I will go back and organize/secure all cables under the panel. Next I added sockets to all the wires on the left wing root CPC connector and fastened it to the fuselage side with two fasteners. I plan to add the other two, once the test is complete. For the right side, I installed sockets in the right fuselage CPC, but did not cut and install the Garmin roll servo harness. I can't test the system without it attached and plan to cut and install it in the wing when my initial tests are completed.
