I disconnected the power to the boost pump and secured the wires so that they will not ground out when tested. I installed the NAV 1 antenna and the ADS-b antenna on the belly. I connected the positive lead of the battery to the BAT side of the run relay and will connect the other side when I get ready to light up the panel. I set the MINI-X GPS antenna on top of the glare screen....not sure what to do with it yet and plugged it into the unit as I mounted the MINI-X in the panel. I also set in the Garmin GMU 22 Magnetometer and the MINI-X Magnetometer. Using a can of air that removes dust from computers, I blew off the panel compartments and installed the other equipment one by one.
