Installed the fuel transducer this morning. After it was installed, I installed the fuel line from the firewall to the pump, from the pump to the throttle body, from the throttle body to the transducer and from the transducer to the spider. I then reinstalled the left forward SCAT tube to check for clearance. The ALT air cable has to be installed after the mixture cable because they share the same bushing. They were installed and tested for fit. Next, I installed the PROP cable and then the throttle cable. I was happy with the length and fit of all the cables. I removed all the cables except the Mixture. I plan to leave it so O know where to install brake line cushion clamps when they arrive. I placed a small piece of fire-seal on the lower part of the transducer before I installed the fuel lines and plan to finish wrapping it in a couple days.
