Brief Description: Panel Wire Pass Through Doublers
I made, painted and installed the access hole doublers. Now that I have all the loom securing nut plates installed in the ground angle, I went ahead and riveted it onto the sub panel. I also installed the .032 angles on the lightening holes. These angles will be used to secure the main looms with ties. The ties will go through bushings installed in the angles.
