After I got back from flying today, I assembled the ELT bracket that was primed a couple days ago. After the panel is mounted, this will be located AFT of the rear bulkhead. I also Pro-Sealed my rear NACA inlets that will divert outside air into the overhead console. It will be 2-3 weeks before I need to attach the air inlet SCAT tubes, so they will be good and cured.
