Made a bracket to secure my pitot and static lines and installed it on the sub-panel with a nut plate. I then reassembled the panel one more time checking the clearances of the items I just added. They were fine. Next I added some bushings to route the fan wires and Power Stabilizer to a secure location. I also received my 1/4", aluminum faced insulation I need for the side wall. It was cut and installed. And finally, disassembled the unit and attached the fuselage upper to the fuselage. My friend Larry is coming over tomorrow to help me final rivet this in place.
