Larry and Marty came over this morning to help set the panel in place. The panel all by itself is not that heavy, but very awkward. It had to be tipped at an unusual angles and carefully set in place, and finally secured with painted AN 8 screws. As they worked the panel into position, I routed the BAT, ALT1, ALT2 and transponder wires through their bushings. The boys did well.
