Did a little more wiring today. My goal is to get the firewall forward wiring done first. I hooked up the back-up alternator and sensor unit. The sensor is attached to the #10 white wire on the alternator post and has a ring terminal installed about 10" away. I used a ring terminal to bolt it to the #8wire running to the panel. If the current sensor ever goes bad, I can unbolt it at the alternator rather then unwire it at the panel circuit breaker. I also hooked up the start relay, attached the start relay diode and disconnected the starter. The mail alternator shunt #8 shunt wires were connected next. I still have to connect the smaller wires to the panel.
