Installed the oil temperature RTD and wired it to the oil temp shielded twisted pair coming from the panel. Wired the Slick Tach (Engine RPM) sending unit I installed the other day to the Tack 3-conductor shielded wire coming from the panel. Installed the oil, fuel and manifold pressure sensors on the firewall mounted pressure manifold. Installed a Molex connector on the FT-60 Fuel Transducer. Installed pilot cable bracket in the fuselage
