Short day. Going over to KPIA to discuss the external painting process with another builder. Peoria has turned out some very nice planes. Today, with Kris's help, the oil temp butterfly valve control cable was installed and tested. The know is on the lower pilot side of the cable cluster and is secured to the bracket with a cable nut, the steering brace with a cushion clamp and nut plate and finally, through the firewall with a proper pass through connector.
