Brief Description: Oil, Fuel and Manifold Sensor Install
Today I soldered the oil, fuel and manifold pressure sensors to their respective shielded panel wires. Once soldered, I covered each of the joints with heat (HS) shrink tubing and then covered each group of three with another piece of HS tubing. After plugging the pigtails into the sensors, I looped them into their final position and string tied them in a harness fashion. Next, I wired the right side EGTs and CHTs, bundled each connection in their glass sleeve provided by Garmin and tie wrapped them together. Additionally, the EGTs were connected to the valve covers with cushion clamps.
