Installed (for fit up) the fuel transducer and mocked up the fuel line from the spider to transducer, from the transducer to the throttle body, from the throttle body to the fuel pump, from the fuel pump to the fuel pressure sending unit, from #6 manifold to the manifold sensor, from the firewall to the fuel pump and from the fuel selector to the boost pump. With the lines all cut to fit, I boxed them up and sent them to Tom at TS Flighlines for manufacture. They should take about ten days to assemble and cover with fire sleeve. This was a lot of work, but I am happy with the fit. There were only two hoses that were the same length as the ones Vans sells and those were the oil cooler lines. All other are custom fit. Will look a whole lot better. The line from the spider to the fuel transducer will be reworked to include a 45° fitting. The transducer will also be wrapped in FIRE-SEAL.
