The Angle-of-Attack (AOA) computer was difficult to locate because on one end it has a 15pin electrical connection and the opposite end is a manifold for four tube connections and it was recommended to keep it flat. Because the AOA indicator is located on the left side, I decided to mount the computer behind the pilots Primary Flight Display (PFD). I cut a hole in the sub panel giving me access to the 15 pin connector and made an angle bracket to fasten to the left most panel support to secure the AOA computer. I checked the front for clearance by installing the PFD. Looks good.
