Brief Description: Oil cooler vent and control cable work up
I secured the oil cooler valve with two #6 nut-plates and SS screws. The action was really smooth. I then cut a piece of aluminum to represent the cable control bracket so I can work on the other cables without damaging the one I received from Aerotronics with my panel. Once that was done, I started to locate my glare screen fans. I also made a couple doublers for the underside. I could not find anyone who has a 3 3/8" knockout punch and it will not fit on my drill press, so I am going to hand cut it.
