TERRY'S WEB SITE
Date:  1-9-2015
Number of Hours:  8.00
Manual Reference:  37.2
Brief Description:  Fuel Transducer Bracket
Finished riveting the forward heat duct in the tunnel. I had left it loose until I relocated the FT60 fuel transducer. Over the past year, I have read about RV10 builders that have relocated the fuel transducer away from the boost pump because the boost pump causes erratic readings. I removed the two fuel lines I made about a year ago and replaced it with one from the boost pump to the firewall. I made an angle to fasten to the front of the engine and attached a bracket I made to support the transducer. All will be wired when I install the panel.
Fuel Transducer Bracket Front
Fuel Transducer Bracket Bottom
Fuel Transducer Initial Install
