Today I rough fit (bolts snug) both sides of the exhaust system to the engine. There are 6 nuts that are not supplied that I plan to order. I called Clint at Vetterman, (exhaust manufacturer) and asked him about the 6 cushion clamps. In the Vans mock up they used "high temp" white cushion clamps, but they send the standard ones. He said he has had no complaints or warranty claims. I decided to replace these six with the "high temp type" and will use the originals to secure my wiring where heat is not a factor. The exhaust system will be removed to drill holes for the exhaust probes when they arrive. Also, I had enough time to safety wire the air-box top to the throttle body. These four bolts require the safety wire because if one came loose, it could be sucked into the engine.
