I installed the air box mixture arm relief piece in the side of the air box. Was a lot more trouble then I thought it would be...but in the end, turned out nice. I then started on the auxiliary air inlet sliding door. After finding center and cutting a hole in the bottom of the air box, I lined up the steel door jam and drilled it in place. It was recommended that a doubler be added to the inside of the air box. Sometime ago after reading about air box repair after a few hundred hours I made a doubler just for this install. After cleaning up all the cuts, and dimpling all the holes, I installed it for a final fit. Looks good. Tomorrow I plan to add the drain line and scuff for paint.
